Building a-c wc engine
Luke Olson
12-20-2002 19:10:43
I have an allis wc that i pull and i am building an engine for it for pulling. I am going to run the wd45 crank, wc/wd 4 1/8 over bore pistons. distributor, with the electronic ignition,the big late D-17 manifold, with bored intake ports. and the big carb. for the late D-17.I might have big stainless steel valves put in the head also. Does anyone have any suggestions for me. good or bad. thanks for the help.luke
Earl
12-22-2002 13:53:32
 Re: building a-c wc engine in reply to Luke Olson, 12-20-2002 19:10:43
Before you get carried away with big intake valves make sure you can tuck them in the cyl.Years ago I put Buick valves in a WC head and the bore wasn't big enough for the valves to clear.
chuckstr
12-27-2002 13:15:07
 Re: Re: building a-c wc engine in reply to Earl, 12-22-2002 13:53:32
When working on the head make sure that you polish the exhaugst ports to a mirror shine and consider having your cam. ground
chuckstr
12-27-2002 13:14:21
