3500# Farmall H
Nate
12-21-2002 22:07:55
I have an H tore down in my garage, and between now and spring I need to get the tractor down to at least 3250. (I weigh 230) Does anyone have a tip to lose weight? The tractor that is! I want to pull it in the 3500# classes. Thanks
National Puller
12-23-2002 18:37:03
 Re: 3500# Farmall H in reply to Nate, 12-21-2002 22:07:55
Fill the rear end with expanding fome to displace some of the fluid. The reabon they originaly carried so much fluid was for cooling when spending hrs. & hrs. in the fields. After cleaning, fill with foam then trim where needed with a knife. Most all the super stock tractors do this.
WILDMAN
12-23-2002 04:36:09
I HAVE A SUPER H A REG. H ALREADY WIEGHS A LITTLE LESS .I HAVE IT DOWN TO 3200# ALUM TRANS PLATE LIGHT WIEGHT FRONT END, ALUM WHEELS FRONT AND BACK WITH 16.9S, ALUM FRONT RACK , ALUM MOTOR MOUNTS ,FIBERGLASS GAS TANK. 2GAL ALUM TANK INSIDE, ALUM FENDERS. YOU CAN ALSO REPLACE TRANS COVER AND CUT SOME WIEGHT OFF FRONT BOLSTER .ALL THIS IS LIKE HORSEPOWER IT IS NOT CHEAP! HOPE THIS HELPS AND EVERYONE HAVE A MERRY CHRISTMAS AND REMEMBER THE REASON FOR THE SEASON.
APULLER
12-22-2002 13:53:37
Nate first off,how serious do you want to get?
HERE,you need to get rid of to stock gas tank,replace with a fiberglass one,put a 2or3 gallon tank up front,move your battery up front also,replace your axle housings with W-4's,weld on plates,cutt or replace top cover,DISPLACE oil in rear between bull geers,re-do seat,aluminum wheels all around,replace motor mount blocks,replace motor rear plate with STR.grade aluminum,SHOULD I KEEP GOING?
Ohio M Puller
12-23-2002 08:03:11
 Re: Re: 3500# Farmall H in reply to APULLER, 12-22-2002 13:53:37
Where can I get my hands on some weld on axle plates for a H? Please give me a phone number.
Ohio M Puller
Deal With It Pulling
hpuller
12-23-2002 09:53:41
 Re: Re: Re: 3500# Farmall H in reply to Ohio M Puller, 12-23-2002 08:03:11
There is a gentleman by the name of Dave Brugger that built me a set last summer for my H. He sometimes advertises in the Hook magazine. They were reasonably priced and he did an excellent job building them. If you are interested, e-mail me and I will give you his phone number.
WILDMAN
12-23-2002 09:00:47
GO TO A WELD SHOP HAVE THEM MADE NOBODY THAT I KNOW OF HAS THEM.
hpuller
12-22-2002 08:10:05
I pull a H and you will need to use steel pressed wheels and probably weld on axle plates instead of hubs. My H will make 3500 with 14.9X38 tires with this set up. If you are running bigger tires like a 18.4X34 I dought you make it unless you use alot of aluminum. I weigh 250lbs. You will need to strip off everything(belly pump,lights,air cleaner, belt pulley) A lighter front end will help like one off a 460.If you have any questions email me.
Farmall Daddy
12-22-2002 07:50:17
I know that it can be done. 1. Remove the hydrolic pump, 2. Remove the PTO shield and fenders, 3. If you pull from the drawbar, not the hitch but the flat piece of steal, remove the hitch tongue, 4. Run with ONLY enough gas for you to pull,{ add a little octane booster to get more power}, and 5. If this doesn't get you down enough, you'll have to find spoked rear wheels. An H that has enough horsepower can really compete with the WC Allis'
doug
12-22-2002 06:19:43
How much did your H weight before you took it apart?
