Block rockwater leaks
Shaggy
12-24-2002 11:39:22
I was wondering if block rock will seal a wet sleeve setup.What Iam thinking about doing is taking a farmall Aor B block and put in a 31/2 in piston & sleeve in it. I will have to bore the block a little of center to do this. Will this stuff seal the block or should I use something else with it.I found the right pistons and the sleeve stock and a old cracked block to play with.Thanks. Shaggy.
Jrred
12-31-2002 05:46:37
 Re: Block rockwater leaks in reply to Shaggy, 12-24-2002 11:39:22
Shaggy we have sealed cracks with JB weld it has done very well for us If you are just pulling this tractor hard block it and be done no more leaks
Will
12-25-2002 06:41:58
Don't go crazy on the press fit, use a die grinder with a ball nose burr and grind a groove in the bottom sealing surface and fill it with silicone sealer and smear a little on the sleeve and press it in. Do 1 hole at a time (bore to size for the sleeve) because when you press in the sleeve it will close up the next hole a little bit and by the time you get to the other end it will be very tight, some people have cracked the block by not doing one hole at a time.
