Denny's carb
Dave
12-25-2002 21:52:03
I was thinking about getting a distributor with electronic ingition thru denny's carb shop for my IH 400. I would appreciate some advice on the merits of this product. We are mostly stock and pull in the farm stock classes.
G-MAN
12-26-2002 13:52:27
 Re: denny's carb in reply to Dave, 12-25-2002 21:52:03
The same electronic ignition set-up is probably available at your local NAPA, CarQuest and so on. We get the Pertronix (which I believe is what Denny's sells) kits we install in New Generations right here at the loca auto parts store - usually the next day, and the money stays here locally. Just make sure you specify negative or positive ground when you order it. You might also consider recurving your advance to get the most you can out of the distributor. Some local repair shops still have the distributor testers needed to do it quickly and accurately, and once again you can have it quickly.
Mike B
12-26-2002 13:39:22
Call Matt at motec 765-963-6628
Jason
12-26-2002 12:08:40
The electronic ingition is a great thing,but I wouldn't get it at Denny's. Im sure you will be told why by others! There are other places you can get get them. Dennys is WAY to much $$$$$
Roy
12-27-2002 18:05:15
 Re: Re: denny's carb in reply to Jason, 12-26-2002 12:08:40
I AGREE WITH JASON!!!!! !!!!! !!!!!
