Hotter Mag
kevin
12-26-2002 11:19:46
I have a 49 G puller with a wico type X Mag. It is totally rebuilt with hot coil. I was wondering if it was worth the money to install the bigger rotor. Thanks in advance.
Earl.S
12-28-2002 06:23:11
 Re: Hotter Mag in reply to kevin, 12-26-2002 11:19:46
How do you know that you don't have the schedule 8 magnetic rotor now? Wico factory says they made a running change in the early 1940's. What kind of gap will your mag jump at low speed on the mag test bar as slow as your mag will run but not on impulse, without dropping either cyl??? That is what tells you how good your mag is.
