Dennys Governor for M Farmall
JIM
12-30-2002 19:44:20
How well does Dennys governor work?
Farmall Daddy
12-31-2002 07:08:46
 Re: Dennys Governor for M Farmall in reply to JIM, 12-30-2002 19:44:20
Just wondering, what will this do to horsepower, lugging power, etc?
DRT
12-30-2002 19:52:28
All it is, is a "ROCKET" govener. You can get them at a CaseIH dealer and save yourself some money.
drr
12-31-2002 12:49:24
 Re: Re: Dennys Governor for M Farmall in reply to DRT, 12-30-2002 19:52:28
Rock-it governor.
deadeye
12-31-2002 01:55:25
You could re-work it yourself and do as good as what he does. Order a 65 lb. cot spring out of McMasters, stick a screwdriver between every other coil and twist so the spring has a little working room. Presto----you got it unless the linkage is worn. Then you need to do a little more tweeking plus adjustments of the 1/4 in bolts.
JIM
12-31-2002 06:08:51
 Re: Re: Re: Dennys Governor for M Farmall in reply to deadeye, 12-31-2002 01:55:25
Deadeye, How do I contact McMasters? I never heard of them. A cot spring? Any certain length? Are you saying that the spring needs to be more flexible? I thought that replacing the spring with a stronger spring made governors work better and that they get fatigued and need to be replaced or are you saying that the cot spring would be too much and needs the relief to work properly? You can e-mail me if you do not want to post your reply. jbradley@mwci.net
TimC
12-31-2002 12:46:10
 Re: Re: Re: Re: Dennys Governor for M Farmall in reply to JIM, 12-31-2002 06:08:51
www.mcmaster.com
