Best pulling tips
Dave
01-02-2003 18:08:27
I was wondering what all of you pullers out there consider the single (or more than one) best idea, such as a driving strategy, weighting/balancing the tractor, hitch height/length, tire air pressure, tire size or engine modifications that have gained you that extra couple of feet on the track that made the difference between winning and losing. Let's have a discussion!!!
steve
01-14-2003 19:51:28
 Re: Best pulling tips in reply to Dave, 01-02-2003 18:08:27
electronic ignition man theres no other way to fly get rid of the points...no more rpms but alot more horsepower
770
01-04-2003 11:18:26
No doubt balance is very important, but...TIRE PRESSURE, TIRE PRESSURE, TIRE PRESSURE!!!!! !!!!!
During the day the sun hits tires and pressure grows, during the night pressure drops with cooler weather. Set the pressure to get the "magic wrinkle" and you'll be suprised. Remember, pulling is about having fun but when you can pick up an extra few feet free you gotta love it!
a puller
01-03-2003 15:50:21
I would have to say balance of the tractor. It mainly comes down to the distribution of the weights.
Slo Mo
01-03-2003 16:37:39
 Re: Re: Best pulling tips in reply to a puller, 01-03-2003 15:50:21
Have to agree. If you don't have traction, horsepower can hurt more than it helps. Especially in limited speed classes.
Jeff
01-03-2003 17:29:16
 Re: Re: Re: Best pulling tips in reply to Slo Mo, 01-03-2003 16:37:39
I agree. My 88 will spin out if the balance is not right in first gear. Have to use 2nd to get the engine to lug down right and not spin the tires. Find some people who are pulling the same type tractor you are and listen to what they say. What works for one might not work for you but if you get enough ideas eventually you'll hit the right combination. biggest problem I have is that this is Farmall and JD country, not alot of Olivers to watch and study.
slow mo57
01-03-2003 14:58:37
More times than not it for me is reading the track.If for example 12 guys ahead of me go to bad spot because the leader went there that is not always the best spot.I would rather gamble on loosing distance on a new spot or a little differt read of the track to win the class than be happy to spin out in one of 24 holes or maybe get real lucky make it thru.All are tractors fords MM445&IH M we had are all under powered.But read the track, little balance and some luck I have gotten a win or a good placing.
kspuller
01-02-2003 20:29:54
Don't get to thinking to much. Hook to the sled-close your eyes-pop the clutch--open the throttle-- and go till the flagman yells stop. Okay(so much for the humor)It's really a matter of paying attention to all the above questions that you asked and trying different set-ups until you find the right ones for your tractor and you. And don't be afraid to ask questions at the pulls you are at whether pulling of watching. Most of the time you'll get a straight answer.
doug
01-03-2003 07:42:07
 Re: Re: Best pulling tips in reply to kspuller, 01-02-2003 20:29:54
I agree, it's the big picture. Each small change has an effect on several other aspects. I view the dynamics of a puller as a wheel, with BALANCE being the hub which all other factors revolve.
Agent Orange
01-03-2003 19:28:18
 Re: Re: Re: Best pulling tips in reply to doug, 01-03-2003 07:42:07
I too agree. Balance is critical but setup will vary from track to track or day to day. A good habit is to get a note book and write things down. Having fun is what its all about anyway...win lose or draw. But you can't beat the felling of a full pull!
