Rock-It Governor
306m-puller
01-03-2003 12:44:56
Does anyone know where I can get a Rock-It Governor for an M? thanks, LM
rocket govenor details and description here
01-04-2003 08:51:16
 Re: Rock-It Governor in reply to 306m-puller, 01-03-2003 12:44:56
Precision fully hardened weights are pinless, thus reducing friction and giving a quicker response. New design fully hardened weight carrier accomodates for pinless weights.
One peice hardened thrust sleeve. Improved rockshaft bearings.
Uniball linkage gives positive control to carb, minimum wear, easy adjustment and is self aligning.
Improved spring and weight balance.
Instant response, no surging, no sticking.
Field test prove increased performance as much as 20 percent. Available for M thru 450.- H thru 350. -460 thru 856. Current price is $435.00 for a new assembly. Special order only.
Don L.
Austin Mn
ph 507 433 0073
What are they?
01-03-2003 19:05:47
I never heard of a Rock-It Governor? What type of advantages will it give? Thanks
people say
01-04-2003 17:27:12
 Re: Re: Rock-It Governor in reply to What are they?, 01-03-2003 19:05:47
I've heard people say that it really does make the tractor seem more powerful. in reality it's not stronger, it can only open the carburetor up as much as it can be, it just does it quicker.
randy hall
01-03-2003 18:34:01
i have one that i would take $375 for.
Don L.
01-03-2003 12:47:50
I sell them new for $435.00. Don L.
ph 507 433 0073 am best
Matt
01-03-2003 15:04:42
 Re: Re: Rock-It Governor in reply to Don L., 01-03-2003 12:47:50
Hi, Are parts available to convert regular governors or are they completely different. Thanks.
drr
01-03-2003 22:00:08
 Re: Re: Re: Rock-It Governor in reply to Matt, 01-03-2003 15:04:42
They are the old MW governors and they are a kit you install in your governor housing.
