Can I or Can't I?
JeffsCase
01-03-2003 23:27:38
Can I pull a 930 Case at most tractor pulls. I've heard the rules won't allow it because of the year model but they began building them in 1959. So, can I or can't I pull?
MOLINE MAN (Hillbilly Hooker)
01-05-2003 19:59:52
 Re: Can I or Can't I? in reply to JeffsCase, 01-03-2003 23:27:38
Sure you can just as long as you dont win all the time. Let me win now and then
Jim M
01-05-2003 13:34:06
If the rules are 59 and older and they are checking your out of luck. Case started the 1960 tractors in October 1959 but they call them 1960' and that is what they go by. Find you a 900 tag and take the long black stripes off and put the metal Case emblems on the nose piece and call it a 900 and almost no one will know the difference. That is if it has the front mounted fuel tank.
docjoe
01-05-2003 13:30:03
is your 930 a six speed chain drive if so call it a 900 few can tell the difference most dont care any way need a serial number tag let me know i have some. joe
joecool
01-04-2003 16:50:23
Since 930's were produced starting in 59 you can pull in most places. It just depends on who is running the show. You can always remove/ or replace serial number plate as only major diffrence is serial number. Is it gas or diesel and where do you live? A friend pulls his 930 everywhere we go.
www.southernantiqueiron.com
A.P.
01-04-2003 10:02:52
Find out what your local rules are. You may be able to pull it locally. If not find out what year is the cutoff and then find a Case 600, 900 or 500.
Good Luck,
A.P.
Paul
01-04-2003 03:39:06
Your 930 was built in 1960-61-62.Most pulls are 1959 and older.
