Good way to lose weight on a Case 930?
Willie
01-04-2003 17:51:15
Hi, I've got an old 930 standard tractor, wondering how some good ways to loose some weight, the p.t.o housing is real big, wondering if it can come off and be blocked with a plate, or does this housing have to be there to carry a bearing on a shaft,etc. Also, does anybody know if a different hub wil fit the front spindles on these tractors, I'd like to get something besides the heavy cast hubs with 18 in. rims. Thanks, Willie
doc joe
01-05-2003 13:14:17
 Re: good way to lose weight on a Case 930? in reply to Willie, 01-04-2003 17:51:15
I have a 900 case i run in the 5500 wt class get in touch if you would like my diet plan joe.
Jim M
01-05-2003 06:51:25
The rear cover off of a L or LA will fit. The ones with no PTO or Hydralics have a nice eagle cast on them. The front hubs off of most later Case treactors will fit. Look for some 6-hole hubs off fo a 730 or like tractor. There are 2 weights in the nose you can take out. We have a 900 down to 8500# with no problem.
Willie
01-05-2003 19:45:36
 Re: Re: good way to lose weight on a Case 930? in reply to Jim M, 01-05-2003 06:51:25
Hey Thanks Jim, How much would be a fair price for a p.t.o cover plate like you mentioned, and are they easily found or scarce? I live in TN., and you don't see a whole lot of Case tractors here. Thanks, Willie
Jim M
01-06-2003 17:05:51
 Re: Re: Re: good way to lose weight on a Case 930? in reply to Willie, 01-05-2003 19:45:36
Check with Ruscha or Don Livingston. I think you can get one for $150
Donnie
01-05-2003 06:49:20
I don't know a lot about cases, but our 930 Standard, (1965) has the hubs for press steel wheels on it. They say the later 930ck standards like ours came with that type of hubs. Hope this helps.
buckmaster700
01-06-2003 06:25:40
 Re: Re: good way to lose weight on a Case 930? in reply to Donnie, 01-05-2003 06:49:20
pull your pto and get a aluminum cover for it i used old road sign and polish it up or get diamond tread pull off your seat and rock shaft and top trany cover make a aluminum cover there and a seat mount pull off your fenders and have some weld on hubs made for the rear its abut 70# lighter than cast clamp on hubs
buckmaster700
01-06-2003 06:24:43
pull your pto and get a aluminum cover for it i used old road sign and polish it up or get diamond tread pull off your seat and rock shaft and top trany cover make a aluminum cover there and a seat mount pull off your fenders and have some weld on hubs made for the rear its abut 70# lighter than cast hubs
