Champion Plugs
Andrew Sears
01-06-2003 20:36:28
What is the AC equivelant to the Champion D21 plugs?
David
01-08-2003 07:51:42
 Re: Champion Plugs in reply to Andrew Sears, 01-06-2003 20:36:28
I wouldn't run AC plugs. They could be free and the only plug available, I would quit pulling instead of running them. I ran them one time when I couldn't get any Champions and that was the ONLY time I have ever had a plug foul on me. It cost me a win in the class, ended up 8 feet behind winner on only 3 cylinders. I've ran Champions ever since with NO problems. If I couldn't run Champion, I would go with Autolite.
works well
01-08-2003 06:08:44
the autolite 388 is a great plug works well with various amounts of octane. 1.98 at NAPA
Farmall Daddy
01-07-2003 16:19:07
I also have a '49 M that I pull, and I run the hottest AC plug that is avaliable. In my own opinion, if you run you tractors rich, the AC's will last longer.
redbrand
01-07-2003 19:03:02
 Re: Re: Champion Plugs in reply to Farmall Daddy, 01-07-2003 16:19:07
the cross from a champion d-21 which is the hot plug is the autolite 386.. very common plug.dont like the champions either...
Andrew Sears
01-07-2003 09:17:34
Thanks for the reply's. I have a 49 M puller and I have been using Champion D21's. I've got domed 4.375" Arias pistons in it at 12:1 compression, and I was wondering, John Brawner, how much longer are the AC's than the Champs. Surely they aren't much longer, as not to hit the top of the piston. The tractor runs ok with the Champions but I was just wanting to see how the AC's worked out for me. Thanks again guys.
John Brawner
01-07-2003 09:03:26
AC C88L IS A BETTER PLUG WITH A LONGER REACH! JUST MY TWO CENTS,JOHN
Irv
01-07-2003 07:12:28
C 87
