Bill Bear's heads
Jrred
01-16-2003 05:24:29
A lot of talk about Bear's 560 heads on here but do any of you know what you are talking about? They are not ford heads,nor are they any kind of farm tractor heads! They came off of a IH diesel engine for a truck and were converted to gas! They are a cross flow head that by all rights have no reason to be on a antique pulling tractor! I don't think that even today there is a cross flow head on a farm tractor much less 40 years ago!
Jrred
01-19-2003 10:27:00
 Re: Bill Bear's heads in reply to Jrred, 01-16-2003 05:24:29
I'm sorry I thought that all you pullers would have known that I ment gas cross flow heads! I'm not talking diesel after all he is running gas I may need some schooling but I know gas from diesel! Now someone tell me about a GAS cross flow head on a tractor?
Look in to the crystal ball......lol
01-19-2003 20:18:01
 Re: Re: Bill Bear's heads in reply to Jrred, 01-19-2003 10:27:00
obviously this isnt cleo or the physic hotline....were not mind readers just pullers....
pcy
01-16-2003 17:24:13
i dont have a dog in the hunt, but a 460 and 560 dsl were cross flow, i know of one alky ss that used the dsl block and head , the dsl block has one less headbolt than a gas, a little trick they done so you couldent switch heads
Jrred needs a schoolin'
01-16-2003 13:25:42
A word from the wise..... Stupidity is a dangerous thing....and here is a good example.. Next time do some research before opening your mouth....therefore you will not have to stick your foot in it later.....
JDGnut
01-16-2003 10:52:49
Deere has been using Crossflow heads for over 30 yrs... JDGnut
max puller
01-17-2003 18:09:21
 Re: Re: Bill Bear's heads in reply to JDGnut, 01-16-2003 10:52:49
30 years is a stretch is'nt it.The Guys running Derre's had to work real hard to not get thier butts kicked by the IH guys for the fact that IH 1466 were cross folow. Just a dum farm boy remebering the old days of super stock. Also my question to Bears heads being legal are do or don't the rules state no converting deisel heads to gas?
Heads
01-19-2003 20:14:11
 Re: Re: Re: Bill Bear's heads in reply to max puller , 01-17-2003 18:09:21
They are not diesel they are 2 v-8 gas heads cut and welded together...
max puller
01-17-2003 18:08:55
max puller
01-17-2003 18:08:37
Paul
01-16-2003 12:11:42
Wich JD has crossflow heads . I really cant think of even one????? ? just asking
Paul
01-16-2003 12:11:34
JDGnut
01-16-2003 12:43:30
 Re: Re: Re: Bill Bear's heads in reply to Paul, 01-16-2003 12:11:34
Engines.. 6329 (6 cylinder 329cid) yr 1965 ( believe the the 6303 was a crossflow too.. 1964.. was changed to the 329 the next year) 6359 (6 cylider 359cid)
6414, 6068 (6 cylinder 6.8L)
4029
6045
6105 6 cylinder 10.5L
6125
Used in various combines and tractors.
JDGnut
Slow up
01-16-2003 08:29:02
The D21 had a cross flow head. Shows what U know.
Slow up
01-16-2003 08:28:54
The competiton
01-16-2003 12:25:33
 Re: Re: Bill Bear's heads in reply to Slow up, 01-16-2003 08:28:54
Boys if you don't want to pull against stuff like that, stay out of div. 5! He isn't the only one with stuff like that and for your information, a 460 diesel had a crossflow head and so did an 88 oliver diesel. I don't guess ya'll could see that with your head stuck up your anis!!
The competiton
01-16-2003 12:25:03
Boys if you don't want to pull against stuff like that, stay out of div. 5! He isn't the only one with stuff like that and for your information, a 460 diesel had a crossflow head and so did an 88 oliver diesel. I don't guess ya'll could see that with your head stuck up your butt!
The competiton
01-16-2003 12:24:55
