How to figure C.I.D.
shaggy
01-17-2003 06:54:22
Hello I just wanted to know if I am figuring cubic inches right. bore x bore x stroke x number cylinders x.7854. I won't put the spec's because you guy's get more out your push lawn mower's. Thanks.
shaggy
01-21-2003 22:16:27
 Re: How to figure C.I.D. in reply to shaggy, 01-17-2003 06:54:22
Thanks everybody for the help. I figured it up and I have a grand total of 132cid. Hey its a small tractor. Thanks again
Farmall Daddy
01-19-2003 10:30:16
I do belive that you take the bore X the stroke X the number of cylinders.
What?
01-19-2003 14:03:13
 Re: Re: How to figure C.I.D. in reply to Farmall Daddy, 01-19-2003 10:30:16
So a 5" bore x 7" stroke 4 cylinder motor would be 5x7x4=140 CID. Yep, sounds right to me.
Chevy2500
01-20-2003 06:45:28
 Re: Re: Re: How to figure C.I.D. in reply to What?, 01-19-2003 14:03:13
That makes my Chevy 350 about 6.5 bore x 6.75 stroke x 8 cylinders. WOW
FARMALL BOY****THE EASIEST WAY****
01-18-2003 10:54:13
go to>Link
Tony630
01-17-2003 14:38:30
Make it easy on yourself - bore X bore X stroke X .7854 X no. of cylinders = Cubic Inches.....
Tony630
Eric
01-17-2003 09:27:58
This link will calculate displacements and more.
http://www.appletreeauto.com/engcalc.htm
pcy
01-17-2003 09:05:55
you guys have me cornfused here is how we do it, punch .7854 in your calculater mutiply x your bore x your bore again x your stroke x your no of clynders, example .7854 x 4.3 x 4.3 x 4.75 x6 tells you a 1066 ih cube 413.8783
Ohio M Puller
01-17-2003 08:48:10
Here is the easiest way:
Take your bore size:
ex: 5"
divide by 2
equals 2.5" then multiple that to itself, 2.5 x 2.5 = 6.25 then multiple that to PIE (3.14) which is 19.625. Next you multiple that to your STROKE ex: 6" that is 117.75". Lastly, you multiple that to how many cylinders you have ex: 6 that is 706.5 that is your cubic inches.
(Bore radius)^2 x 3.14(PIE) x Stroke x No. of Cylinders = Cubic inches
Ohio M Puller
Deal With It Pulling
Ohio M Puller
01-17-2003 08:48:06
ex: 5"
divide by 2
Ohio M Puller
Ohio M Puller
01-17-2003 08:47:58
ex: 5"
divide by 2
Ohio M Puller
Slo
01-17-2003 08:25:10
I use bore x bore, divide by four. Then multiply by pii, 3.14 take that and multiply by stroke, then that number by number of cylinders. For example, a stock MM U has 283 cubic inches. 4 1/4" bore by 5" stroke with 4 cylinders
4.25 x 4.25 = 18.06
18.06 / 4 = 4.51
4.51 x 3.14 = 14.16
14.16 x 5 = 70.8
70.8 x 4 = 283.2
Hope this helps
Tom
01-17-2003 07:38:35
Math is not my favorite thing so I go to Antique Tractor pulling web site. They have a c.i.d caculator even tells you liters.
WTW
01-17-2003 07:19:23
Use .7854 not 7854. The way I do it is A x S X N = D. A is area, To achieve it take the bore X the bore X .7854. Example would be if you had a 6 cylinder engine with a bore of 4" diameter and the stroke was 4.5. First figure the area. 4 X 4 X .7854 = 12.5664 (area) Then take the Area X the Stroke, 12.5664 (Area) X 4.5 (Stroke) X 6 (Number of cylinders) = 339.2928 (Displacement)
Jerry
01-17-2003 16:37:52
 Re: Re: How to figure C.I.D. in reply to WTW, 01-17-2003 07:19:23
If you have heads with the valves recessed up in the heads I believe you have to add the volume of the recess. I gave away the latest Green Magazine but I believe they had an article that described how to seal off the valves and pour into the heads water that after you pour it out can be calculated for volume. I believe that the moline page has a chart that gives the ci for each of there stock head's along with the compression that was tested when new and stock.
C.I.D., not compression ratio
01-18-2003 06:27:49
 Re: Re: Re: How to figure C.I.D. in reply to Jerry, 01-17-2003 16:37:52
Volume of the heads is for figuring compression ratio, not cubic inches
Pi x R2 x stroke x # cyl is cid
volume with piston at bottm DC over volume with piston at T.D.C is compression ratio
Get a good calculator, don
G Taylor
01-18-2003 19:15:22
 Re: Re: Re: Re: How to figure C.I.D. in reply to C.I.D., not compression ratio, 01-18-2003 06:27:49
There's a person who understands how things work.
