Price for Pulling 450
Farmall Boy
01-18-2003 10:36:12
We are thinking abpout buying a Farmall(of course) 450 and where wondering what would be a good price on one with really good paint(not new) lightened up to 6,000 with good wheely bars and weight brackets, good sheetmetal, 90 hp from stock stroke and bore????? ????? ??tires are very sharp and uncut and ooooo yea a set of wheel weights THANKS YALL
G-MAN
01-21-2003 17:38:46
 Re: Price for Pulling 450 in reply to Farmall Boy, 01-18-2003 10:36:12
I'm not a Farmall man, but it looks like there are a few knowledgeable ones telling you that 90 horse isn't possible with a stock bore, and you might want to listen to them. If he's sure it's got 90 horsepower, I'd run it on a few different dynos to verify it. It's not uncommon for dynos to be twenty horsepower or more off, especially if it hasn't been recently calibrated or isn't well-maintained. You also aren't mentioning what RPM it's producing that horsepower at. Pulling an engine down past rated will almost always increase horsepower. I can make about any tractor produce 20 horsepower more than it actually has just by leaning on the torque bar. Since you don't seem willing to listen to knowledgeable guys that are doing their best to help you, you'd better just buy it and find out what it is for yourself.
Farmall Boy
01-23-2003 09:51:55
 Re: Re: Price for Pulling 450 in reply to G-MAN, 01-21-2003 17:38:46
I listening but this guy is also very knowledeable and knows what he's talkin bout
Farmall Daddy
01-19-2003 10:15:22
You can to get 90 horsepower out of a 450 standard block. You can bore it out, and not run sleeves in it, which I know for sure if you run 10% over, you can to get 116 horsepower tops. I would pay around $3500-$4750 for one like that, if he has proof that it does produce that much power.
re- read it
01-19-2003 15:29:51
 Re: Re: Price for Pulling 450 in reply to Farmall Daddy, 01-19-2003 10:15:22
it said stock bore!!!
randy hall
01-18-2003 19:39:07
the only way to get 90 horse from a 450 engine by just changing the pistons and head is either run about 3000 rpm's or use denny's out of adjustment dyno to test it.
Farmall Boy
01-19-2003 09:45:52
 Re: Re: Price for Pulling 450 in reply to randy hall , 01-18-2003 19:39:07
! know he was pulling division 3 so i don't think it was 3000 rpm and i don't know how much the feul would affect but he was running 114 octane??
randy hall
01-19-2003 11:00:41
 Re: Re: Re: Price for Pulling 450 in reply to Farmall Boy, 01-19-2003 09:45:52
the fuel doesn't help any unless you have the compression to need it.
Farmall Boy
01-19-2003 14:47:16
 Re: Re: Re: Re: Price for Pulling 450 in reply to randy hall , 01-19-2003 11:00:41
That's what my dad told him but it is a high comp. engine
ihm394
01-18-2003 18:27:48
Unless you get into the water jackets you'll never get to 90hp with a stock stroke.
Farmall Boy
01-18-2003 18:59:42
 Re: Re: Price for Pulling 450 in reply to ihm394, 01-18-2003 18:27:48
Well thats wrong!! he put some Keneth Black high dome pistons in it and i think u can close to that with just a lp head???
Farmall Boy
01-18-2003 19:03:15
 Re: Re: Re: Price for Pulling 450 in reply to Farmall Boy, 01-18-2003 18:59:42
SORRY!!!!! I didn't mean for that to come off that rude
ihm394
01-20-2003 10:15:57
 Re: Re: Re: Re: Price for Pulling 450 in reply to Farmall Boy, 01-18-2003 19:03:15
I have built several stock pulling engines. 4-1/4 bore and a stock stroke, LP Head and a 10.3 to comp. ratio would yield no more than 75 HP. The only way I know of to get 90 with a stock bore would be to get 1/2" stroke crankshaft.
PRICE IS PRICE
01-18-2003 10:49:51
One in good, shape sells up here in MI for about $3000,there starting to become all the rave.just my $1.98
