Bloc Boring -- How Big?
52BMAN
01-21-2003 10:40:37
What is the most I can bore the stock bloc on my late JD B? Could I go 0.190 over stock? What kind of HP gain would this give me? Thanks!
Ron
01-22-2003 08:59:14
 Re: Bloc Boring -- How Big? in reply to 52BMAN, 01-21-2003 10:40:37
Original compression ratio was about 4.65 to 1
Raising it to 7 to 1 ( or higher) will make a WORLD of difference...you Won't kill it in 1st....!!! Not sure what compression ratio I have but I have to open the pet-cocks to start it... +180 and a set of "Allied" pistons a mechanic found for it, installed in 1960.. It will start sometimes, when warm, w/petcocks closed...pulls a 2-14" just 1 gear faster than the other identical "B"..... I don't think you will really need that much bore ( and that costs a lot ) I wonder if a set of JD 520 pistons would work..they are 7:1....LP pistons are even higher...!!!
.250
01-21-2003 18:55:03
.250 over is safe...I've heard some say .300 over.
.250 - addition
01-21-2003 18:55:33
 Re: Re: Bloc Boring -- How Big? in reply to .250, 01-21-2003 18:55:03
that's without sleeving it. sleeve it and you can go huge.
G-MAN
01-21-2003 17:32:38
I can't say how far you can bore your block, but I can tell you that you won't see major power gains by just a simple overbore. Big gains are made by increasing stroke, compression, breathing and the like. Boring does increase displacement, but not nearly to the extent that stroking does, unless you go to a power-block.
