14.9x38 vs 15.5x38
Paul
01-22-2003 15:38:37
for all practical purposes which is better? i knowthe 14.9s are bigger but I feel the 15.5s may have an advantagebecause of a shorter stiffer sidewall > also do both have the same wheel width rating( 15.5x38 on a 14" rim.) thanks___Paul
Ethan
01-22-2003 18:46:38
 Re: 14.9x38 vs 15.5x38 in reply to Paul, 01-22-2003 15:38:37
With my stock worn out MM U I still could compete fairly well with the shorter 15.5 because I was a little shy for power. Better gearing. We'll see what 75 hp does with them now. I might switch who knows. My two cents.
Farmall Boy
01-23-2003 09:41:50
 Re: Re: 14.9x38 vs 15.5x38 in reply to Ethan , 01-22-2003 18:46:38
We have an M that for the first half of the season had 15.5's that had reely short hard cleats then switched to 16.9's with a new big cleat and did terribly and now we our lightening up an are going to 14.9's this comin season and will poast how we do
max puller
01-22-2003 16:07:26
Its a good way to change the gearing in your tractor, if you can't quite pull 2nd gear with 14.9s it my haul it on the shorter 15.5s. Just my two cents keepon pulling.
Wicky
01-22-2003 15:54:45
I run a set of 15.5x38 on a John Deere "B" that are sharpened and am very compeitive. It all depends on the way that they are cut. My personal opion you got to have the right tire to match the track. can't really say which is better they are a lot of the same to me.
