crank 4 stroking a 88
Charlie
01-24-2003 04:04:25
I have a good 1600 gas crank. Has the larger rod journals for off set grinding to stroke an 88. Can set you up with 77 rods and car pistons to give you a mini stroker kit. Email me for details.
A.P.
01-24-2003 13:16:02
 Re: crank 4 stroking a 88 in reply to Charlie, 01-24-2003 04:04:25
Charlie what are the rod journals on the crank you have? The 1600's I worked on have a 2.25" rod journal, the same as a Fleetline 88. Of course some have been updated to a 1650 crank or engine at some time. The Super 88, 880, 1650 crank has 2.437 rod journals which gives a bit more stroke when going to 77 Fleetline rod journal size (2.0"). Strokes could be 4 1/4" or 4 7/16" or close to it depending on which crank is used.
Regards,
A.P.
