Light weight JD A
2 HAL JD
01-26-2003 14:39:57
looking for help to lighten up my 1952 JD A. My class rules state stock appearing. Have pressed steel wheels. Would like to know how much weight I can lose taking the hyd.- PTO- rockshaft out. Need to keep cast rear cover by rules. Weighs 5360 with cast wheels. Thank you
520-LP
01-27-2003 19:34:03
 Re: light weight JD A in reply to 2 HAL JD, 01-26-2003 14:39:57
K&K has a aluminum flat back that the battery box will fit on that is molded from an orginal back for around $200.00 www.kkantiquetractors.com
2 cylinder
01-27-2003 15:11:49
I pull with a 47 JD-A. I have the flat back on it with the PTO in, 15.5x38's on pressed wheels, removed the roll-o-matic front end and went with the smaller and lighter implement rims and tires on the front, and taken the oil bath system out, and have the old style seat and it weighs in at 4500 lbs. I am running with a magneto so after I start the tractor I can pull the battery, and I can remove the generator also and be at 4400#, this with wheelie bars and weight brackets and myself (200#)on it. Just going with a smaller size set of implement rims and tires on the front will lighten you up by 50 lbs. Hope this helps.
JDBert
01-27-2003 13:04:06
I took the power trol off, made a plate useing the gaset as a template then gutted the "pump" on the pto. With 15.5's on pressed steel my 51' weighs around 5000.
Mike in Mo
01-27-2003 06:00:06
If I remember correctly (it's been a few years) I lost 225# by taking off the rockshaft housing and using cast roundback on an early styled A. I guess you could use an early platform and seat, but that setup weighs about 50#, but you could use an aluminum channel instead of steel and get rid of the spring. If you only pull with it drain out tranny lube down to about 3 gallons. Mike
Mike in Mo
01-27-2003 05:59:32
will
01-26-2003 19:38:57
I have a cover for your A if you need one
2 HAL JD
01-27-2003 14:53:37
 Re: Re: light weight JD A in reply to will, 01-26-2003 19:38:57
wondering what it would take to get the cover from you. trying to pull on a budget like most people.
mike
01-26-2003 18:11:50
get a 4109R rear cover, has a jd part number, they cant fight that one. gets rid of all the hydaulic housings and stuff on that.
2 HAL JD
01-27-2003 14:57:44
 Re: Re: light weight JD A in reply to mike, 01-26-2003 18:11:50
I agree but, only found one so far and couldn't afford the price. Would still appriciate help to find one at a better price.
2 cylinder
01-27-2003 15:18:15
 Re: Re: Re: light weight JD A in reply to 2 HAL JD, 01-27-2003 14:57:44
I bought my flat back for $225 last spring, and there were more where that one came from. That was the cheapest price I could find after shopping around, they go for WAY more than that at most every other places.
2 HAL JD
01-28-2003 04:03:21
 Re: Re: Re: Re: light weight JD A in reply to 2 cylinder, 01-27-2003 15:18:15
I would like to know where you are located and if the flat back cover is the JD 4109. Would like to try to work something out.
Thanks
Will
01-28-2003 06:20:38
 Re: Re: Re: Re: Re: light weight JD A in reply to 2 HAL JD, 01-28-2003 04:03:21
The cover I have is A570R. It is in good sape and if someone would like it I'll let it go for $100. I live in Wisconsen and i'll even pay for the shipping just to get it out of the shop.This cover is off a 38A and should fit some of the newer ones also.
