560 IH engine swap
Rob
01-27-2003 12:00:15
Will a 815 combine engine fit in a 560 Farmall?Thanks
Tony
01-27-2003 19:33:08
 Re: 560 IH engine swap in reply to Rob, 01-27-2003 12:00:15
Which engine? early 815's had a 407....later 815's had a 414....either one can be made to fit in a 560....
Keith
01-28-2003 16:14:42
 Re: Re: 560 IH engine swap in reply to Tony, 01-27-2003 19:33:08
Will they fit into a 460? What has to happen to make one fit a 560?
baby bear
01-27-2003 12:42:34
Yes it will, then get a set of V-8 IH truck heads, make an intake manifold and you're set!
Baby bear huh!
01-27-2003 14:48:56
 Re: Re: 560 IH engine swap in reply to baby bear, 01-27-2003 12:42:34
Gee.. I thought that daddy bear did all of that work to a 460. The guy was trying to find out information on a 560. Glad somebody was smart enough to answer his question!
Rumor has it
01-28-2003 18:34:38
 Re: Re: Re: 560 IH engine swap in reply to Baby bear huh!, 01-27-2003 14:48:56
Watch out for the new 460 IH 630 ci. thats going to be running div. 5 this year..... Give Yall Somethin' to Think About..... .
Too late
01-28-2003 18:48:33
 Re: Re: Re: Re: 560 IH engine swap in reply to Rumor has it, 01-28-2003 18:34:38
Bill Bears 460 is already running and it has 740 cid. The 766 IHC engine in his tractor can beat those big MM and Case 900s most of the time now.
not too late...should be obviously too stupid....
01-29-2003 18:12:53
 Re: Re: Re: Re: Re: 560 IH engine swap in reply to Too late , 01-28-2003 18:48:33
...Oh great one look in your crystal ball and tell us how you get 740ci out of a IH 766 360 ci. block ..... anxiously waiting your reply...
Talk to Lemmons
01-29-2003 19:41:31
 Re: Re: Re: Re: Re: Re: 560 IH engine swap in reply to not too late...should be obviously too stupid...., 01-29-2003 18:12:53
Talk to Lemmons they built this engine. The 766 block has more room between pan rails than 301. You could also talk to Bill about this. Watch this tractor pull the wheel speed is tremendous but not always his ground speed he usually spins out while everybody else powers out.
Hey stupid.
02-01-2003 23:20:51
 Re: Re: Re: Re: Re: Re: Re: 560 IH engine swap in reply to Talk to Lemmons , 01-29-2003 19:41:31
theres not enough room in a 360ci. 766 engine for that kind of cubes.. been there , did it , done it got a dt466 to build...
Come On
01-30-2003 19:39:06
Greg- It doesn't matter if he's still spinning his tires, if he's spinning them into 3rd place (like 5500 at Murray). Sure makes him look smart for causing so much controversy for building a 3rd place tractor.
Confused
01-28-2003 22:24:57
Have you seen the results from the last few pulls, the "Magnet" 460 has been taking it from the 900's and especially the G-6's!
