Cummins motor for pulling
Brad
01-28-2003 16:15:52
I have a white tractor with a Cummins in it. I am turning it into a hot farm and super farm puller. It is the big motor I think the cubic inch is 585. How do you all think this tractor can do against all the other brands of tractors? I think it will be fairly competitve. THANKS
D13
02-01-2003 03:11:46
 Re: Cummins motor for pulling in reply to Brad, 01-28-2003 16:15:52
You've got the small cube early Cat engine, right?
Swap in a 3208, 636CID. Somwhere back in the archives there's a picture of an oliver 2255 running the CAT. It might have an e-mail address for Marty and maybe he can help some.
loverboy
02-01-2003 05:59:59
 Re: Re: Cummins motor for pulling in reply to D13, 02-01-2003 03:11:46
I seen Oliver pull with CAT V-8 at state fair this year it really tore out of the the hole like a rocket dirt flying smoke blowin, and rods all over the ground. if you build CAT just be sure to bring a spare.
Re check
01-28-2003 18:11:37
I think the 585 is a Minnie Mo engine. MM used it in the 1350/1355. The The 505 is the Cummins. In trucks it is known as the 8.3
