IHC M for stock class
carl
07-02-2001 01:52:22
I just bought a farmall M to work and pull in the stock class. What are some almost legal modifications that I could do during a rebuild? Would a dist with Pertronix do better than the mag? What is the best size rear tire to run? any certain brand? Other tips appreciated.
Greg H.
07-02-2001 13:35:06
 Re: IHC M for stock class in reply to carl, 07-02-2001 01:52:22
I'm not an IH man but if you are pulling in a truely stock class I wouldn't worry too much about modifications. Just get the ignition system improved like you stated that you were going to do, adjust your carb correctly, and I'm sure you will be competitive with any other tractor that is stock and of the same weight. Just consentrate on getting it running right. Tires, well it all depends on what is allowed size wise, but 15.5 x38 old {used } armstrongs or firestone feild and roads 23 deg. bar. 14.9x38 firestone field and roads wouldn't go bad either. Later on Greg H.
