Case900 diesel
chotalen
02-03-2003 17:51:22
what kind of hubs do i need for the back to put tin on the back it has a tapered axle
dean
02-04-2003 17:49:48
 Re: case900 diesel in reply to chotalen, 02-03-2003 17:51:22
a good machinist can fabricate a set of steel hubs with the duplicated taper as you need..probably a few dollars to do..also can remove axles and turn a flat in a bigger lathe and use a set of m&w style hubs..have seen both of these scenarios done
WHEEL DEAL
02-04-2003 12:14:09
THERE ARE NO HUBS TO BOLT ON IN ORDER TO PUT PRESSED STEEL ON YOU WILL HAVE TO WELD ON AXLE PLATES
ITS JUST THE NATURE OF THE BEAST
Jim M
02-04-2003 16:35:34
 Re: Re: case900 diesel in reply to WHEEL DEAL, 02-04-2003 12:14:09
I was talking to a guy at the Lawerenceburg TN show that told me he made a set of hubs for his 900 to use pressed steel
