Allis Chalmers wd45 puller
Rodney Whittle
02-04-2003 18:07:20
I have a WD45 gas with (14.9) 28 tires.What would be the best classes to pull in?
Farmall Daddy
02-05-2003 17:59:24
 Re: Allis Chalmers wd45 puller in reply to Rodney Whittle, 02-04-2003 18:07:20
Original. Try to get down to the 3501-4500, should compete in that class.
Allis Puller
02-05-2003 12:28:21
The stock tractor without taking anything off you should weigh around 3850-4000 with you on it. It is very possible to get it down to 3500# and there you will be extremely competetive. You may need pressed steel rims to do so, and the lift arms and PTO will have to go. And another thing is it a wide front? I don't know as it can be done with that much weight. If you have any questions email me.
Ohio M Puller
02-05-2003 07:56:37
There is a gentleman around us with a WD45 and he seems to play around in the 4000 - 5000 pound class. The thing is only you know truely how much guts your tractor has and what it will take so you will have to deside. My only recommendation is that you stripe it down as far as possible and add the weight as you need it.
Ohio M Puller
Deal With It Pulling
