5.9 cummins build for oliver
math
04-02-2013 18:02:38
I'm looking for info from people who have built a 5.9 Cummins for pulling. I'm looking to see how big are these motors being built. I know you can get 300-400 hp out of the little 360 but just wonder if they are building bigger or how big they are going.
dgerth
04-06-2013 06:14:17
 Re: 5.9 cummins build for oliver in reply to math, 04-02-2013 18:02:38
Go to the Turbo Diesel Register web site. They deal only with cummins stuff.
dg
180doug
04-05-2013 01:49:14
Aaaa yeah the Walmart talker guy needs to get Diesel Power Mag, the heads, bolts, valves are all good for 1200 hp stock, its easy to get 1000 from the little cubes, with more fuel + air and like said, tons of parts, cheap too!
M.Genrich
04-04-2013 18:42:34
This intrests me. I know Math who made this post And im sure we will hash this subject over on the phone soon. I know what we can get out of a DT468 with a four inch turbo, P-pump, and a big bore so 1000 to 1200 hp from a stock long block 5.9 sounds pretty wild to me. Has any one ever done this or are they going by what they read in a magizine? How many rpm are we talking here, and does any one have an Idea what this will cost? Im sure math will want to have an idea what the cost will be. And so will I! Thanks.
South pull
04-06-2013 08:58:34
 Re: 5.9 cummins build for oliver in reply to M.Genrich, 04-04-2013 18:42:34
Some of the performance truck builders do it regularly. Contact beans diesel performance down in Tennessee. They have built a lot of tough running 5.9s for pullers and drag racers.
180doug
04-03-2013 19:03:45
M.Genrich
04-03-2013 18:40:36
A 1000 hp. from a stock 5.9 cummins? Id like to see that! Walmart sells comic books I guess!
gtx1967jewison@yahoo.com
04-04-2013 06:30:30
 Re: 5.9 cummins build for oliver in reply to M.Genrich, 04-03-2013 18:40:36
Its a FACT buddy. I know several. Watched lots of em pull. Drag strip etc. All external bolt on parts.
southpull
04-04-2013 17:24:25
 Re: 5.9 cummins build for oliver in reply to gtx1967jewison@yahoo.com, 04-04-2013 06:30:30
M.Genrich you must not be familiar with 5.9s or the performance world. A set of head studs, and maybe valve springs/pushrods are the only engine mods needed to hit 1000 hp. That, with big injectors and big turbo and 1000 hp is done all the time on those motors.
nick from md
04-03-2013 01:29:25
If you 're going to overhaul it you should try to find a 6.7 crank. You 're right I don't care what engine you are building there is no replacment for displacement.
Bouncer
04-02-2013 19:07:09
The question is how how big do you want to go? Do you want a 1000hp, 1500hp, 2000hp, 2500hp? My '95 12v below put out a little over 500hp and was my daily driver and trailer puller. The 12v are very easy to build power with and there are tons of parts out there.
third party image
math
04-02-2013 18:59:10
I know those guys are doing that but I have to overhaul the motor and there is no replacement for displacement.
Bouncer
04-02-2013 19:10:53
 Re: 5.9 cummins build for oliver in reply to math, 04-02-2013 18:59:10
You do not need any more displacement. You need to learn about pumps, turbos, injectors, compression ratios, etc before worrying about more displacement in a 5.9 Cummins.
Super Pinky
04-02-2013 18:25:49
The association in our area hast a pro street diesel class and the boy r pumping out around the 1300horse mark
VicS
04-02-2013 18:10:11
Need to get a Diesel 4X4 magazine at Walmart. My son showed me a article where you could get 1000 hp without any internal modifications. Just turbo's (I think 2 at least maybe 3) lines and pump. Vic
