How much power can JD 830 put out?
JON
02-06-2003 14:45:06
How much power can you get out of a JD 830 and what are some of the tricks to get it to perform?
thanks for any info.
bigmotors
02-07-2003 14:29:15
 Re: How much power can JD 830 put out? in reply to JON, 02-06-2003 14:45:06
Open up the rack for one. Next size bigger injectors. Play with the pump. They like alot of air. I have a bone stock 830 I did. New old stock STD. block and pistons. I have done nothing to it. 78hp. at 540. It will pull down to 105hp.and stay there all day long. Just giving you a idea for hp. Only pulled it once, had a ball.
Good Luck!
Gpower
02-07-2003 15:25:58
 Re: Re: How much power can JD 830 put out? in reply to bigmotors, 02-07-2003 14:29:15
What are you doing for bigger injectors?
bigmotors
02-07-2003 21:52:41
 Re: Re: Re: How much power can JD 830 put out? in reply to Gpower, 02-07-2003 15:25:58
To tell you the truth, I don't know. I was told this by a friend, he made it very clear it took him a why'll to figure it out. He would not tell me. Sorry about that. I know he put a huge pump on, and then took it off, and went back to the stock one but, had it gone threw for pulling. He said he made more power with the injectors, then when he put the big pump on.
77 puller
02-07-2003 05:12:24
How thicks your wallett???
