How light can you get a AC 210 ?
Kim
02-06-2003 18:02:31
How light can you make a allis chalmers 210, with no cab, no weights, no 3 point, no cast wheels, just dual hubs and steal rims, 20.8 x 38 tires.The one I have weights 16,400 lbs with 3 big weights on the inside wheels and fluid in the tires and a cab,it sure would be fun to pull with if you could get it down a long ways!Any Ac 210 pullers our there. Thanks
John
02-07-2003 11:09:50
 Re: How light can you get a AC 210 ? in reply to Kim, 02-06-2003 18:02:31
I'd get the fluid pumped out of the tires and find a few more weights to make up for the fluid. That would allow you to get into lighter classes. You could also take fuel out of the tank; all but about 5 gallon. These would be a few easy things to do before you start changing front ends, rims, and cast pieces.
Hope this helps!
John
Phil Munson
02-07-2003 07:55:12
There was, years ago, a 220, from Canada, which was very competitive in the 9000 SS, 12000 SS and 12000 open.
the pink panther
02-07-2003 04:09:27
i had a 190xt SS that weighed 5700 with me on it.lots of alum.
HAHAHAHA
02-07-2003 19:03:15
 Re: Re: How light can you get a AC 210 ? in reply to the pink panther, 02-07-2003 04:09:27
U did not have much!!!!! !!!
mike
02-06-2003 21:55:54
Kim, you could get that 210 down to 8000lbs if you really wanted to. I'm in the process of getting my d21 down to 7300lbs. It just takes some fabrication, a lot of aluminum, and determination, not to mention all the beer and firewood for the long nights in the shop! I had a 210 and the rear casting is a little beefier than the 21, but just about everything else is lighter. The front end is very heavy and you could probably lose a 1000 pounds up there.
Slo
02-06-2003 19:04:37
There is a D21 that pulls in 8500 farm in this area.
