Plug wires
Jason
02-08-2003 11:43:34
Where is a good place to get high quality plug wires? They will be on a Farmall M. Most automotive ones can't be cut so I need to know where I could get the right length. Alot of the plane old copper kind I noticed can not be used with electronic ignition. Any help will be appreciated! Thank you!
MH55
02-09-2003 09:35:19
 Re: Plug wires in reply to Jason, 02-08-2003 11:43:34
Go to your local Autoparts chain. (Autozone, Advance, Checkers, etc). Ask to see the Accell and the MSD catalogs. Both companies have universal fit 4 and 6 cylinder wiresets with one end crimped to wire and the other end in a bag of parts. If you are planning on doing multiple sets pony up for the Accell crimping tool. It will make the job much easier. It is kind of expensive for a pair of pliers though... They also have replaceable jaws so you can crimp other types of wire connectors. And as for the wiresets they can be ordered in a multitude of colors, copper and spiral core. 8mm 8.5mm 9mm stock to full race specs...
just a message from your friendly nieghborhood autozone employee/tractor puller...
