How wide of rim for 16.9x38?
Andy
02-09-2003 11:05:20
What is a good rim width for 16.9x38 tires? thanks.
Jack
02-10-2003 09:28:46
 Re: How wide of rim for 16.9x38? in reply to Andy, 02-09-2003 11:05:20
Hey there Andy.I could not find 15 wide wheels anywhere and it was either 14 or 16 inch.The rules where I pull say that unless you are using 18.4 38's on 16 inch rim than 15 inch is maximum with 16.9's.I ended up having a set of rims 12 inch widened to 15 inch.16.9 38's look and fit great on a 15 wide wheel.Good luck.
2 cylinder
02-09-2003 18:54:20
I'm running mine on 14.5 inch rims at about 12-13lbs of air. Works very well for me, and have trophies and prize money to show for it.
Allis Puller
02-09-2003 18:17:50
We used a 16" rim, and it bites the ground really hard. If you go to wide then you loose tire height and inturn wheel speed.
tazfarmer460
02-09-2003 18:09:36
I have mine mounted on 18" rims. The wider the rim you use the flatter the bars will be on the ground.
Farmall Boy
02-09-2003 13:05:15
15 in
