Framall H how big of pistons
chot
02-10-2003 15:50:28
how big of piston can you put in a framall hwith stock rods
randy hall
02-10-2003 18:26:05
 Re: framall H how big of pistons in reply to chot, 02-10-2003 15:50:28
piston size is irrelevant to the rod. the amount of stroke is what changes your rod length.
Steve
02-11-2003 17:22:48
 Re: Re: framall H how big of pistons in reply to randy hall, 02-10-2003 18:26:05
If your gonna do all that you mine as well use up the extra stroke thats already there. Thats where your torq is! Gain cubes&compression! Cant tell you all the tricks to do it may have to hook against ya good luck! Steve
hpuller
02-10-2003 17:20:48
You can use farmall 350 pistons but you will have to buy some bushing to make them fit properly. You can buy the bushings from CaseIH.
RK
02-10-2003 18:52:21
 Re: Re: framall H how big of pistons in reply to hpuller, 02-10-2003 17:20:48
You can put the farmall 350 pistons in but you will have to have the block bored for the sleeves to fit also.
DOUG
02-11-2003 04:38:28
 Re: Re: Re: framall H how big of pistons in reply to RK, 02-10-2003 18:52:21
I RUN 4 "60 OVER
