ATTN: ALL 460/560 PULLERS
Adrian C.
02-12-2003 09:54:30
We made a mistake.....the rpms need to be reduced to 30% over and NOT the extra rpms we are currently allowed. Many people are complaining we have an unfair advantage...AND WE DO!! Let's prove we can win legally!! Vote to get our rpms taken back down! Come on all you other brands...talk to your NATPA board members and let's get them taken back where they should be!! See you in Colombia, Mo!!!!
Concerned Fan
02-13-2003 18:46:02
 Re: ATTN: ALL 460/560 PULLERS in reply to Adrian C., 02-12-2003 09:54:30
Adrian..... Cox???? You are acting kind of hypocritical from what i saw at murray kentucky..now i may be wrong but it looked like you weren't pullin the throttle all the way back so a tech. offical assisted you a little and then some one brought some wrenches over and worked around the governor area????? after that the 460 or 560 whatever u hav wasn't as hot as the first pull.. DON'T TAKE THIS PERSONAL i know u have a good tractor F.B.
billybob
02-13-2003 20:39:47
 Re: Re: ATTN: ALL 460/560 PULLERS in reply to Concerned Fan, 02-13-2003 18:46:02
Sounds like Adrian wants to lower the rpms to me, If he gets the clutch to quit slipping in the 460 hes not going to need rpms he'll need a seat belt.,
Fan
02-15-2003 17:27:32
 Re: Re: Re: ATTN: ALL 460/560 PULLERS in reply to billybob, 02-13-2003 20:39:47
YEA...RIGHT!!!!The tech offical had to get on there to make sure he was pullin it all the way back and was still under rpms???
E J
02-13-2003 14:11:47
Here in my area we have 560s pullen with dt466&414 in them .That makes a fine ride.
E J
02-12-2003 20:52:06
A 660 has the same motor as 560 282 but it is rated at 2400 rpm 30% over is 3150rpm.What motor is a dt360?
Bear's Illegal Motor
02-12-2003 22:12:22
 Re: Re: ATTN: ALL 460/560 PULLERS in reply to E J, 02-12-2003 20:52:06
That's what a dt360 is.
RPM'S MUST BE LOWERED!!!
02-12-2003 20:09:32
The rpm's on 460's and 560 HAVE to be brought back under control! It's bad enough that they get almost 1000 more legally than any other brand, and then when a well known board member and his buddy wind them even tighter, how are others supposed to compete? Another thing is, how in the heck does a dt360 get to run 660 rpms? I thought the train of thought behind letting 460 and 560's run 660 rpms was because their motors were supposedly the "same". I don't think that a motor that you can fit 250 more inches in could be considered the same. Any responses made by board members (you know you read this) would be appreciated.
What about?
02-12-2003 10:16:53
Did you ask Bill Bear if it is OK to lower the RPMs?
Good one
02-12-2003 15:28:49
 Re: Re: ATTN: ALL 460/560 PULLERS in reply to What about?, 02-12-2003 10:16:53
Good one that is right. Better big Bill approval on the Bill otherwise it won't become law.
billybob
02-13-2003 06:39:47
 Re: Re: Re: ATTN: ALL 460/560 PULLERS in reply to Good one, 02-12-2003 15:28:49
You cry babys better hope they don't go together on div3, div 4 tractor and spoil all your fun, better let sleeping dogs , Sleep.
JoeBob
02-13-2003 08:32:42
 Re: Re: Re: Re: ATTN: ALL 460/560 PULLERS in reply to billybob, 02-13-2003 06:39:47
Bill Bear can't win now with his POS. Why would I be afraid of him if he get the rules changed so he can pull Div 4 or even Div 3. He still won't win.
If I was a JD puller, I would be talking to Bear about a 4010. Get him convenced on how good they are and POOF. The 4010 will somehow be legal to pull. I'd bet it would even get to run 4000 RPMs. He might even get the M&W Turbo to be legal.
