Cockshutt 40 gas
cockshutt road
02-12-2003 18:44:54
just bought a 40 thinking bout reboreing it and put in larger sleeves and pistons.what would it cost and is this the most hp i can get for my money and do you have to do anything else to the engine.dont have a pile of money to put in it right now but just wanted to try something.im a poor man with a poor mans tractor but im not gonna let the red ones take all the tropheys home .wife said should have taken it on to the junk yard while it was on the trailer
David Berger
02-19-2003 12:32:33
 Re: cockshutt 40 gas in reply to cockshutt road, 02-12-2003 18:44:54
I wouldn't go ruining a good old cockshutt
tractor.I'd just leave it stock.Here in Ohio they seem like they're non existant.
Shutt 30
02-14-2003 20:04:16
The factory 230 block can be bore to 3-9/16. Get a 273 Buda block as it is already 3-3/4 bore and can be bored to 4" with out resleeving. You wont have very much room between the cyl bore and the head studs so keep the comp ratio under 10 to 1. No room for o-ringing at 4". Go with a 262 crank it will give you 1/4' stroke. If you stroke much more you will need to knotch the cam. Just stroking the 273 with the 262 crank will be a world of difference over the 230. My $.02.
Good luck
max puller
02-12-2003 21:47:05
Not much room inside of 230CI motor find a 262CI from a Gleaner combine will bolt right in give it a good tune-up it will give the M Farmalls a run for their money in 5500 and up stock weight class's and you won't spend much money with his set up and will have something for future building.
Jerry
02-14-2003 13:04:58
 Re: Re: cockshutt 40 gas in reply to max puller , 02-12-2003 21:47:05
If your 40 is like my 30 with a Budda in it you can bump the piston size 1/8 with different sleeves. In the case of the 30 a Chrysler 4 will fit it. Maybe the Chrysler six would also fit and it may be easier to increase the Chryslers power.
few changes
02-13-2003 20:17:10
If you want to change to a 262 you'll have to put the back plate and flywheel from the 230 on it. You'll also have to make a front motor mount. The 262 crank will fit right in the 230 and give you 1/4" more stroke. You'll have to knotch the factory cam or change to the 262 cam (already knotched). Stock 262 is 72 horse. 230 with nothing but 262 crank will run close to that. Right pistons, compression, and fuel setup will get you as high as 85.
JDGnut
02-14-2003 09:05:45
 Re: Re: Re: cockshutt 40 gas in reply to few changes, 02-13-2003 20:17:10
If is like the other 230 engines.. the 262 sleeves will fit, but the oring grooves will have to be cut into the liners. this will give U a few more.. JDGnut
JDGnut
02-13-2003 18:37:30
Does that have the 6 cylinder Buda 230 gas engine??? Just curious, thanks. JDGnut
cockshutt rd
02-14-2003 17:49:43
 Re: Re: Re: cockshutt 40 gas in reply to JDGnut, 02-13-2003 18:37:30
yes jdgnut it is a 230 6 cylinder
Iowa Farmer
02-16-2003 19:32:55
 Re: Re: Re: Re: cockshutt 40 gas in reply to cockshutt rd, 02-14-2003 17:49:43
Is that the same engine that is in the Wards tractors?
Iowa Farmer
02-16-2003 19:31:42
