440 CI Farmall M HP???
Anique Puller
02-13-2003 14:39:46
Anyone running a farmall M with around 440
cubic inches? how much horsepower have you seen
on the dyno? What head, carb, and manifold setup did you use?
Red puller
02-15-2003 06:19:55
 Re: 440 CI Farmall M HP??? in reply to Anique Puller, 02-13-2003 14:39:46
The only thing more variable that some of these older dyno's is the guys who read them. So don't get to discouraged if someone else's 'story' is a little bigger than yours. Let them do there talkin' out on the track!
However, you should be able to make between 115-120 hp @ 535 pto rpm.
Farmall Daddy
02-15-2003 18:51:17
 Re: Re: 440 CI Farmall M HP??? in reply to Red puller, 02-15-2003 06:19:55
An M's rearend will fail before it could hold 100 horsepower. The 450's are putting 85 horsepower and the can't hold their driveshafts and torques in my area. Just my 2 cents.
supermpuller4
02-15-2003 19:17:52
 Re: Re: Re: 440 CI Farmall M HP??? in reply to Farmall Daddy, 02-15-2003 18:51:17
The m's rearend will hold up fine at 200 hp. I know of a lot of 460's running 100 to ? hp, rear end TA are holding up just fine.
02-16-2003 18:33:59
 Re: Re: Re: Re: 440 CI Farmall M HP??? in reply to supermpuller4, 02-15-2003 19:17:52
there are guys putting 500+ HP small blocks in Farmall M's
max puller
02-17-2003 16:39:11
 Re: Re: Re: Re: Re: 440 CI Farmall M HP??? in reply to ?, 02-16-2003 18:33:59
There was a guy in our area back when the modified class started { showing my age} had a super sharp Farmall M with a 396 big block Chevy very high HP for the day don't remember seeing it broken ever.
