Bolt my hitch
Rick
02-16-2003 18:07:39
I am building a tractor for the 3500 and 4500 lb antique classes. I am going to bolt my hook point on the bottom of my drawbar. Will 3 bolts 3/4 of an inch in diameter be enough to hold the bottom piece? The pieces bolted together are 1 inch flat bars. The hook has a u shaped piece welded on the outside. Also would ready rod be enough or should they be grade 5? Thanks for the help.
JD4020
02-16-2003 18:52:33
 Re: Bolt my hitch in reply to Rick, 02-16-2003 18:07:39
get hardened bolts. I use the ones that have a gold color to them... not sure what grade they are off hand without looking. A good way to adjust the height is to buy bolts that are longer than you need and buy washers to fill the space between the draw bar and th hitch.
