JD A starter
Jason
02-18-2003 15:29:20
I have an unstyled A stroked and bored I am going to use the early styled a flywheel and crankase plate. my question is will the stock starter work or should I look for a later model starter and which one? thanks to all who reply.
Drew
02-18-2003 16:42:27
 Re: JD A starter in reply to Jason, 02-18-2003 15:29:20
A stock starter in good condition will work. We have a stock starter on ours and it will whip it over with the petcocks closed, but doesn't like it sometimes. With the petcocks open it does not have a problem. The starter bracket does flex some when you try to start it with the petcocks closed and I have heard of people breaking the bracket. You should not have a problem with it though if you open the petcocks and bleed some compression off.
