Question about GVI wheels
Jason
02-19-2003 08:26:29
I need to put a set of 18.4x38 wheels on my GVI, club rules say no axle plates. I have a set of 9 hole wheels and tires already mounted any idea on a hub that would work? Thanks
Curtis
02-19-2003 09:52:06
 Re: Question about GVI wheels in reply to Jason, 02-19-2003 08:26:29
Try doing this (I did it on a G and it should be the same on a GVI): use the MM hub but take off the cast wheel between the hub and the rim. Take off the hub and reverse it so the flat side is to the outside. On the steel wheels I had, the four holes for wheel weights would pretty much line up with four of the holes the cast wheel bolted to. I dimpled and drilled four more holes to match the others. Some wheels have a flat center and on those you could cut some of the center out to fit the hub and drill 8 holes to match the GVI hub. You probably wouldn't need to reverse the hubs if you have flat center wheels. If you have to reverse the hubs, the tires will be closer together.
