Delco starter for a deere
rusty
02-19-2003 18:16:08
What is the part # of the Delco gear reduction starter that some of you use, for a top mounted starter on an A or G.
Big Jugs
02-28-2004 16:00:35
 Re: Delco starter for a deere in reply to rusty, 02-19-2003 18:16:08
There is a place in Sun Prairie,WI> that sells starters for 4020 diesels that fit perfectly. If you even have to use a file to remove excess material that would be about it. Nearly a bolt on kind of deal. 189.00, post again if you are interested. Have one on a 11-1 g.
520-LP
02-22-2003 19:04:09
A bob cat starter will work but you have to change the drive gear. cost around 250.00
A puller
02-20-2003 13:31:08
The startr you are looking for is a Nippendenso starter used on the 7710 and like size Deeres. They are kinda pricey 450.00 +++ from Deere.
