Farmall H Bore and Stroke
Morgan
02-19-2003 18:16:57
I have an H and I want to run a 4" piston and 6" stroke. What kind of pistons and what connecting rods can I use in this setup. Any help is would be great...
RANDY
02-20-2003 18:14:20
 Re: Farmall H Bore and Stroke in reply to Morgan, 02-19-2003 18:16:57
measure your compression distant (that is the distance from the center of your piston pin to the topo of your piston not including the step)you have now then deduct 1/2 of your additional stroke you want, this will give you the correct comp. distance. Then look for a piston with a similar pinbore and the new comp. distant. You can bore the block then using darton sleeves and o-ring the lower counterbore.
Lee
02-19-2003 20:00:30
Good luck, I hope you have a good block or you will be in water jackets. I have seen peaple in jackets at 3.75 .
Lee
02-19-2003 19:59:30
