JD 60
AH
07-09-2001 12:04:00
I just came across a JD 60 and was wanting to know if anyone pulls in the stock class with a 60? and What can I do to help me have a good pull?
Zack Peterson
07-16-2001 15:01:00
 Re: JD 60 in reply to AH, 07-09-2001 12:04:00
I pull a John Deere 60 out here in Oregon. It's a stock tractor and I only use 1st gear. I've found that 6000lbs. was a little light for it, so I pull it at 7000lbs., and sometimes 8000lbs. At 8000 it is a little tough to beat tractors like Case 830's, but it is very competitive at 7000. I don't know what your weight classes are like, but if you get the weighting and hitch right, it really amazes the crowd when you chug down the track at 1.5 miles an hour. Remember to have fun with tractor pulling, though, because that is what it is meant for and you'll enjoy it more. A little competition is good, but I've seen it get out of hand. Good luck.
60 man
07-09-2001 18:28:29
A 60 john deere will make a good pulling tractor, if you keep it stock. Don't listen to others and put a gold mine in it, then it's not stock antique tractor pulling!! Boring a motor is for candy a$$ men who are afraid of losing to stock tractors. Pull it the way it is!!!!!
jd man_I forgot--put on a 70 carb--and say it came with the tractor
07-09-2001 17:47:34
That's about it
CottonWood
07-09-2001 21:00:10
 Re: Re: JD 60 in reply to jd man_I forgot--put on a 70 carb--and say it came with the tractor, 07-09-2001 17:47:34
I've seen you at a tractor pull before. You're the guy who used 550 pounds of welding rod on your flywheel and doubled the horsepower of your twopop tractor. Too bad you still finished last.
jd man--BORE and STROKE THE SH!T OUT OF IT!!!
07-09-2001 17:43:03
Then say it's stock. That's what they do around here!!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!! !!!!
Super M
07-11-2001 04:21:04
 Re: Re: JD 60 in reply to jd man--BORE and STROKE THE SH!T OUT OF IT!!!, 07-09-2001 17:43:03
Are you talking about the Deere guys around Winchester, Virginia?
jd man-Remember to always refuse to admit that you have ever done anything to it-I guess It's luck that it dyno's 80HP
07-09-2001 17:56:17
*&%$*^& is what I'm saying
Flyin Farmall
07-09-2001 19:31:24
 Re: Re: Re: JD 60 in reply to jd man-Remember to always refuse to admit that you have ever done anything to it-I guess It's luck that it dyno's 80HP, 07-09-2001 17:56:17
You could always paint it RED!!
Cyrus McCormick
07-10-2001 21:38:20
 Re: Re: Re: Re: JD 60 in reply to Flyin Farmall, 07-09-2001 19:31:24
Paint that John Deere whatever color you like.
That won't change the fact that it's a piece of junk.
John D
07-11-2001 10:50:56
 Re: Re: Re: Re: Re: JD 60 in reply to Cyrus McCormick, 07-10-2001 21:38:20
Well,since I read your post,I think I will just go to the local Farmall deaership and buy me one.Oh I almost forgot,is it close to the JOHN DEERE dealership?
jd man-why do you think JD'S are green?? Because of the f*cking money it takes to make them pull!!!!!!!!
07-09-2001 20:26:26
Gman
07-11-2001 20:12:30
 Re: Re: Re: Re: Re: JD 60 in reply to jd man-why do you think JD'S are green?? Because of the f*cking money it takes to make them pull!!!!!!!!, 07-09-2001 20:26:26
Flin or whtever you name is,you made a true statement but is it nessary to use such language to get your point across.Have a nice day hopefully a better day tommorrow. Gman
