Massey 44
just wonderin
07-09-2001 16:36:17
I'm pullin a Massey 44 next 2 weekends,looking for some quick tricks,it runs strong Ipulled it once last year did good,but not good enough!theres a 3.5 mph speed limit,i've moved tne hitch to 20 high 19 fromcenter of axle,any tips would be appreciated!theres no rpm limit,so Iwired the governor spring titght,should help huh?
Jake
07-10-2001 04:00:49
 Re: massey 44 in reply to just wonderin, 07-09-2001 16:36:17
Get it as light as you can, 44s will make 4500 lbs without too much trouble. Even with a stock engine, you should be able to run 3.5 mph in 1st gear with 15.5 tires and open rpms in this class. You may want play with the timing a bit to try and smooth it up at higher rpms. I would take the tube off between the carb and the stock air cleaner to help her get air. That is about all I can think of that is quick. After that, start throwing dollars at it. :-)
just wondering
07-10-2001 05:45:01
 Re: Re: massey 44 in reply to Jake, 07-10-2001 04:00:49
can't get in at at 4500,damn cast wheels!it makes 5000 with 350#added Iwas gonna pull in 2nd,hope fully it wont be to fast,shoulndt be should it?where do you think timing should be set?thanx alot
one massey puller to another
07-10-2001 18:40:21
 Re: Re: Re: massey 44 in reply to just wondering, 07-10-2001 05:45:01
What kinda track are you going to be on? What kinda motor mods have you made otherwise? If it is a stock tractor, I dont think I would try second gear unless it is a loose track. Especially at 3.5 mph. At that speed, you will never open it up completely. I would stick to first gear and open it up. But, your best bet would be just to build a big motor (500++ CI), run a set of 18.4 38's on aluminum rims, grap 3rd and just play with it. Do that in 4500 to 6500 pound classes. Whatever you do, just beat the Farmalls and Olivers and make us all proud (I wouldnt worry about the other green ones too much)
good luck
just wonderin
07-10-2001 20:35:51
 Re: Re: Re: Re: massey 44 in reply to one massey puller to another, 07-10-2001 18:40:21
it will be a clay track,the motor is BONE stock.Ialready did the hitch,running a straight pipe,&tossed the air cleaner need more cheapo tricks,not 500cubes,only a temporary ride thanx
10x30
07-09-2001 19:59:14
HEAD WORK HELPS ALOT GASKET MATCH THE INTAKE AND EXHAUST PORTS, SHAVE THE HEAD .060,STRAIGHT PIPE THE EXHAUST,AND K&N AIR BREATHER. LET IT BREATH!!!!! !!!!
