JD
G Valve???
Rick
02-21-2003 10:02:06
I tied to get new intake valves for my flat head G part # F51R. Dealer says they are no longer available. Does anyone know what I can use as a substitute replacement and where I might obtain them? Also will the cyclone head valves work in the flat head? Thanks in advance for any and all replies!!
toot
02-21-2003 11:18:13
 Re: JD - G Valve??? in reply to Rick, 02-21-2003 10:02:06
I believe K&K antique tractor lists these valves.
kkantiquetractors.com
Rick
02-21-2003 13:03:39
 Re: Re: JD - G Valve??? in reply to toot, 02-21-2003 11:18:13
Thanks Toot!!! I called K&K and they are sending two intake valves my way on Monday.
G-MAN
02-21-2003 10:51:31
Did your dealer search to find if anyone has them in NOS still? They should be able to do that. If that doesn't pan out, you might consider talking to your machinist. A lot of times they have access to parts sources for items like that. I believe there is an ad in the Green Magazine classifieds that lists NOS unstyled valves, but I believe it's only intake or exhaust, and not both.
