Cam grinding
wags
02-22-2003 07:12:29
What should the lift and duration be for AC, 4 cylinder....280cubes
BIG IRON
02-24-2003 14:18:05
 Re: cam grinding in reply to wags, 02-22-2003 07:12:29
I would talk to Scott at Berry Cam Service in Minnesota (320) 395-2377. He will be able to tell you what you need for your tractor. I had my cam ground by him for stock RPM and was very satisfied. He reground the cam on a 2 cyl tractor as well as reface the lifters for $144.00 including shipping.
Owner of the Buhler poor house
02-22-2003 11:50:11
Must have sold some of that high quality alfalfa hay if you are grinding cams for pulling tractors. Why dont you just get out the hand grinder and do a little bump and grind on it. Watch your fingers Wags.
Captainhookerus
02-22-2003 09:44:39
The AC 175 tracor grind works well even at 425 cu in. Berry cams at Lester Prairie will grind it for you.
wags
02-24-2003 07:54:40
 Re: Re: cam grinding in reply to Captainhookerus, 02-22-2003 09:44:39
thanks for the response about the D-17 can grind. I'm interested in the lift and duration numbers.
There's a place in Wichita, KS that will grind my cam, but it would be helpful to have some specs
dean
02-24-2003 20:26:18
 Re: Re: Re: cam grinding in reply to wags, 02-24-2003 07:54:40
bought a motor with a cam ground by reed cams..somewhere in georgia..was specd. at .321 int and exh..lobe lift..that is what the lobes are ground to..this would give .482 lift at the valve..then ground .233 across for duration @.050..never ran this cam or motor but i hope this will give you something to start from
