Plug in Head G
Brandon
02-22-2003 15:48:50
What kind of plugs should I run in my G. It has a Jerry's head on it. He said he thought that everybody used Champion C63Y. Is this right? How do you get in there to put the plug wire on? Thanks for the help.
Brandon
Gman
02-23-2003 17:47:50
 Re: Plug in Head G in reply to Brandon, 02-22-2003 15:48:50
Brandon I use Autolite 3422,3423,3424. The 3422 is a cold plug also I have a MSD box and a whole bunch of cubic inches and get good performance out of them.I got a little set of spark plug wire removers just reach in there and pull'em out.The reach on the plugs is the important factor if you use to long a plug,the threads will get carbon on them and rake havco with the threads later Gman
richard
02-22-2003 18:51:41
brandon. i use bosch spark plug,there not cheap,there not junk. use a straight boot on the end of plug wire with a little wd40. slide on real nice. later richard. email me
