C264 and C281 blocks
Kenny Chinsey
02-22-2003 20:11:45
Which can I get a bigger machined bore out of? A C264 or a C281 (Super M engine or 450 engine)Someone told me that the only difference in the two was that the sleeves were thinner in the 450 block, which would make it a C281. I need some thoughts.
monster m
02-23-2003 15:20:55
 Re: C264 and C281 blocks in reply to Kenny Chinsey, 02-22-2003 20:11:45
You can bore the c-281 block bigger than the 264
JB PULLER
02-24-2003 16:55:45
 Re: Re: C264 and C281 blocks in reply to monster m, 02-23-2003 15:20:55
you can bore a 264 block out to a 4 3/8,s bore, this is as big as you should go otherwise it makes the block to weak i would also have the block checked for thickness even before you bore it to 4 3/8,s because some blocks are thin in some spots i wouldn,t think of trying this with a regular m block. that just my opinion
