560 pulling tractor
BigRed
02-24-2003 21:26:41
I have a 560 gas tractor. Can anyone help me on how to build a motor for pulling. And yes I know all about the 301, but no body has every told me what cam to use, what pistons, what valve train. Stuff like that. Thanks in advance.
Tazfarmer
02-25-2003 17:37:04
 Re: 560 pulling tractor in reply to BigRed, 02-24-2003 21:26:41
If you are looking to buy an engine e-mail me and we'll talk. I have a 370 c.i. I'm thinking of selling. David
chris
02-26-2003 22:56:32
 Re: Re: 560 pulling tractor in reply to Tazfarmer, 02-25-2003 17:37:04
I have an extra new unused c-301 stroker engine. Forged pistons, stroked and balanced crank,dry blocked, Cam,complete port &polish large valves,Triple valve springs, MSD and Carb ready to run. Best of everything. Built by lemmons. Changing tractor/ engine setup.. other 301 parts available.
Any questions call 740 710-2070
yes
02-27-2003 07:59:45
 Re: Re: Re: 560 pulling tractor in reply to chris, 02-26-2003 22:56:32
Didn't know they worked on legitimate 460 engines, just ones that are in question to being legal?
its legit.
02-27-2003 20:22:02
 Re: Re: Re: Re: 560 pulling tractor in reply to yes, 02-27-2003 07:59:45
yes that is a legit. div. 5 301. and makes plenty of hp. If you need a quality engine and are serious about pulling this is the engine to have.
eric
02-28-2003 06:22:19
 Re: Re: Re: Re: Re: 560 pulling tractor in reply to its legit., 02-27-2003 20:22:02
how many cubic inches, how much power, and how much $$$$$$$$?
Chris
02-28-2003 16:54:26
 Re: Re: Re: Re: Re: Re: 560 pulling tractor in reply to eric, 02-28-2003 06:22:19
For info on engine call 740-710-2070 Thanks Chris
lp puller
02-25-2003 18:32:45
i may be looking for a 560 engine where are you located who built the engine how many pulls on it and of course how much thanks lp puller
Brad
02-25-2003 11:55:55
What are the rules for the class you want to pull in? RPM limit? Lots of variables. Unfortunately its not as easy as what parts to BUY, it comes down to what you can make or have made or even take something and modify it to work for your application. Where are you located.
Be Glad to Help
Best of luck,
Brad
BigRed
02-25-2003 12:00:56
 Re: Re: 560 pulling tractor in reply to Brad, 02-25-2003 11:55:55
I'm located in SE Iowa and the rules vary, but for the most part you can do anything to the tractor as long as it is the original block or replacement. I've already turned it up to around 3 grand and that is as far as I can go. I've had the head planed down as far as it can go, other than that, it's a stock motor. I would just like to get somewhere over 100 hp.
Brad Gray
02-25-2003 14:46:08
 Re: Re: Re: 560 pulling tractor in reply to BigRed, 02-25-2003 12:00:56
Big Red,
Email me.
Brad
gray4010@hotmail.com
BigRed
02-25-2003 11:46:42
I appreciate all this stuff about Bill Bear, but that isn't what I asked about. I wanted to know what I could do to my tractor. If you want to get a discussion started on that I'm sure you could.
stan
02-25-2003 05:57:05
you need IH V-8 Truck heads, a saw, and a good welder! oh yeah, lots of $$$$$$ to spend on this and than enough humilty to get beat by pretty much everybody!
THE LAW MAN
02-25-2003 10:34:22
 Re: Re: 560 pulling tractor in reply to stan, 02-25-2003 05:57:05
YOU POOR LITTLE SORRY CHILD.IF YOU WOULD GET A JOB MAYBE YOU COULD HAVE A STRONG TRACTOR.QUIT YOUR CRYING BEFORE BEAR PUTS YOU IN THE SLAMMER.
DW
02-25-2003 11:43:33
 Re: Re: Re: 560 pulling tractor in reply to THE LAW MAN, 02-25-2003 10:34:22
Who said anything about this bear guy? Isn't it just common to use the V-8 truck heads on any 460/560 fixup? I think almost all farmall pullers to this on a regular basis don't they? Surely noone meant this "guy in question" would ever do anything that s-t-r-e-t-c-h-e-s the rules at all!!
PULLER
02-25-2003 04:14:27
CALL UP BILL BEAR! HE WILL TELL YOU EVERYTHING YOU NEED TO BUILD A TRACTOR THAT WILL KICK HIS APPLES.HE WILL GIVE YOU A PHONE NUMBER TO CALL TO GET ALL YOUR ANSWERS.
