Farmall H governor ?
Lee
02-26-2003 18:12:47
What can I do to my farmall H governor to make it work good for pulling. Were to I get a new spring? What other thing can I do that that are not expensive. I am open for Ideas
Chad
02-26-2003 19:13:54
 Re: farmall H governor ? in reply to Lee, 02-26-2003 18:12:47
I pull a Farmall Super M. I took my old spring out and went to the local hardware and bought a sring that is stiffer (stronger) than the original but the same length. This still allows for full range of throttle. My Super M runs about 2100 rpms at full throttle now. I tried a shorter spring but then the tractor would not idle down. The spring cost me $2.00.
Another trick is to make a straight rod to replace the spring. It looks like a U and fits in the holes where the spring clips in. Guys also go the cheap way and grab some wire and wire it tight. Neither of these ideas allow it to idle down, it will run at half throttle or higher all the time.
Hope I helped.
