Big carb.
case
07-10-2001 13:59:42
I am looking for suggestions on what to use for a carb on my puller, I have a good sized carb on it now, but am not getting enough fuel, any suggestions would be appreciated.
G Taylor
07-11-2001 21:56:45
 Re: Big carb. in reply to case, 07-10-2001 13:59:42
Not enough fuel as in leaning out or not enough air/fuel mixture?
Brad Gray
07-10-2001 16:40:12
Depends on what your rules allow. In our case, (no pun intended) our club has allowed us to run any updraft carb. There are some big zenith's and most popular is an airplane carb. There are several aviation carbs available (I keep a few of each in stock all the time as well as parts for them) depending on your requirements (cfm) Maybe email me with your requirements and I can try and help you out.
Good Luck,
Brad Gray
Tyler
07-10-2001 20:54:07
 Re: Re: Big carb. in reply to Brad Gray, 07-10-2001 16:40:12
Brad what part of the country are you from?
we have alot of pulls with rules like that here.
Tyler
Brad Gray
07-11-2001 04:46:43
 Re: Re: Re: Big carb. in reply to Tyler, 07-10-2001 20:54:07
Tyler,
I'm from western Pa (around Pittsburgh). We pull around here and also in Ohio
Brad Gray
07-11-2001 04:46:37
Tyler,
Tyler
07-11-2001 17:17:31
 Re: Re: Re: Re: Big carb. in reply to Brad Gray, 07-11-2001 04:46:37
Brad,
We are from the North Central part of PA. We run alot with the interstate pullers in southern pa, virginia, and west virginia.
On July 20 there will be a pull at Hughesville PA
they will be running 12500, 13500 farm stock, 2 classes of 8500 Modstock, 5500 and 7000 Nonturbo(1up draft carb or any size or type), and 2 classes of 8000 open.
You don't by any chance know where Jeff Cook's tractor ended up do you? It was susposed to be in PA I heard.
Brad Gray
07-12-2001 04:17:31
 Re: Re: Re: Re: Re: Big carb. in reply to Tyler, 07-11-2001 17:17:31
I heard the same about Cook's tractor, but haven't seen it. I pulled with interstate 2 years ago at Newville. Me and another guy brought our tractors in(4010 JD and Cockshutt 570) he won one class, I won the other. Maybe see you around.
Tyler
07-13-2001 10:35:34
 Re: Re: Re: Re: Re: Re: Big carb. in reply to Brad Gray, 07-12-2001 04:17:31
You will fit right in at hughesville then
Tyler
