Lightening up an M Farmall
Farmall Boy
02-28-2003 14:55:17
What would be the easiest way to get a '39 Farmall M down to about 4300 pounds right now it weighs 4740 with me on it and all it has done to it is pressed steel rims on the back
Ohio M Puller
03-01-2003 17:01:01
 Re: Lightening up an M Farmall in reply to Farmall Boy, 02-28-2003 14:55:17
I was having a weight problem as well with my 1950 M and we dropped alot of weight by building a light weight frontend. As well as lowering the nose a great deal. I have an extra frontend that we built for sale with 12" front tires on it that is ready to bolt right on to your tractor. I am selling it for $250. If you are interested or any other Farmall Puller call me at 419 295 4592.
Ohio M Puller
Deal With It Pulling
Farmall Boy
03-02-2003 14:53:33
 Re: Re: Lightening up an M Farmall in reply to Ohio M Puller, 03-01-2003 17:01:01
how much you suspect we'll lose with this frontend
Ohio M Puller
03-02-2003 18:44:48
 Re: Re: Re: Lightening up an M Farmall in reply to Farmall Boy, 03-02-2003 14:53:33
An Easy 60 Pounds Or So.
Farmall boy
03-01-2003 12:11:44
sorry about that we have took out the pto hydraclics and belly pump my mistake
Flyin Farmall
02-28-2003 21:06:18
Start with the bigger stuff-hydraulics,pto,belt pulley drive.build an adjustable hitch,get rid of u-shaped drawbar.Then start looking at small stuff,do you really need that toolbox half-full of dirt and rusted wrenchs???It don't take too long and it will be there.
jeff
02-28-2003 19:04:59
If the rules will allow it take the PTO unit out and all of the hydraulic unit as well. I am not sure how much more that will get you but it adds up quick. The tree that the lights attach to can come off as well. Heck if nothing else just put helium in the tires..LOL!!!!
Mike
02-28-2003 18:18:03
I have a stock '41 Farmall M. It weighs 4700lbs with me on it. -does not have hydraulics. I was thinking of losing some weight to get to 4500. My M has a mag so I was thinking of losing the belt pulley unit, battery & maybe the starter. -might swap the cast wheels for pressed steel also.
IH Man
02-28-2003 16:29:00
Thats the lightest "M" I've heard of.
Mine weighed in this past weekend at
5530..... no weights ,no liquid in tires. Does have power steering and live hydralics and 15.5X38 rears.I'd like to get down to 5000 lbs..can't see how with all the stuff on it.
ms. joei maxwell
02-28-2003 18:40:49
 Re: Re: Lightening up an M Farmall in reply to IH Man, 02-28-2003 16:29:00
I live in southwest missouri and pull a 1953 Super M. My tractor weight with me on it is 4,400. I have pressed steel wheels too.
IH Man
02-28-2003 20:46:57
 Re: Re: Re: Lightening up an M Farmall in reply to ms. joei maxwell, 02-28-2003 18:40:49
Are pressed steel wheels a factory
option when new? Are they legal in Farm Stock class?
FM...No, but..
03-01-2003 20:12:52
 Re: Re: Re: Re: Lightening up an M Farmall in reply to IH Man, 02-28-2003 20:46:57
They are an OEM replacement, I think. You could/can order them from the IH dealer, so you can run them.
Mike
ms. joei maxwell
03-01-2003 14:18:49
My tractor is a 1953 and where I pull in southwest missouri, kansas, and oklahoma it is considered a classic and my wheels are legal.
Farmall Boy
02-28-2003 16:45:19
are you allowed to run pressed steel rims???thats how it is that light but there are sum that 3500 with their driver on them
