Ignition timing
A Puller
03-03-2003 12:37:50
Just wondering what you guys are running for timing on the JD A's. We are going to try about 20 deg. advance. Am I in the ballpark with this.
We are using a Delco dist off of a 60 and a MSD coil.
Ron
03-03-2003 18:19:01
 Re: Ignition timing in reply to A Puller, 03-03-2003 12:37:50
Just remember....if it HaMMERS, you Have to back the timing down...!!! Or you will ruin the rings, and bearings-Pronto.....!!
Gpower
03-03-2003 14:54:54
Full advance should be at 26 degrees btdc, at loaded rpm. I usually set them around 22-24. Good luck
