CUSTOM WHEELS AND HUBS NEEDED FOR 5 STAR MM
BUSTER
03-03-2003 16:06:41
DOES ANYONE KNOW OF A SUPPLIER OF REAR WHEEL HUBS TO CONVERT A 5 STAR M.M. DIESEL TO 9 BOLT? ALSO CUSTOM WHEELS? NEW OR USED. BUILDING A PULLER
gman
03-03-2003 21:32:50
 Re: CUSTOM WHEELS AND HUBS NEEDED FOR 5 STAR MM in reply to BUSTER, 03-03-2003 16:06:41
Buster,I make custom 9-bolt hubs that slide right on the axle and tighten down they have the wheel studs pressed in them for quick and easier changing of tires.there is now welding needed on the axle.they are $500 a set and weigh half of what the cast do and are a lot stronger. I also cut tires if you needing tires cut or looking for tires let me know.We pull two 5-stars,u,rtu.
RICHARD
03-13-2003 17:35:42
 Re: Re: CUSTOM WHEELS AND HUBS NEEDED FOR 5 STAR MM in reply to gman, 03-03-2003 21:32:50
HAVE A SET BOLT ON HUBS FOR 3IN. DIA. AXLE 9HOLE WHEELS WILL FIT 250. PLUS SHIPPING WEIGHT 70 LBS. EACH
