Super 88
Kevin
03-05-2003 03:00:49
I am building an super 88 for pulling and was just looking for some help. Should I use the super 88 head and get it redone or us an 1650 stock head? Or get that head done and how far can I stroke the crank and bore it out? What carb to us and manafolds? Any and all HELP will be great!!!
Thanks
a.p.
03-06-2003 12:13:13
 Re: super 88 in reply to Kevin, 03-05-2003 03:00:49
It all depends on the rules you will be running under. The 1650 head and manifold set is a nice step up for a stock 88 or a small increase in cubes. How much power are you looking for? 340 (4 1/4" bore) and 360 (4 3/8") cubes is fairly reasonable to build. The next step up is 400 to 420 cubes by offset grinding a Super 88 crank (2 7/16" rod journal) to a 77 journal (2") or finding a Massey 1100/Waukesha 195 crank (2 5/8")and offset grinding it. Past this you will need to have the crank welded up. Let your wallet be your guide.
A.P.
TimC
03-06-2003 06:22:42
A lot of people use the 1100 massey head. I believe it is the 195 gk waukesha head used on the 99. It allows valves sizes in the range of 2.02 and 1.65. Carb size should depend on rpms turned in my opinion. You can go as big as your wallet will let up to around 600 ci. Then you have start moving things.
You can mount the 1100 intake on it or some of the other deisel intakes work well turned upside down.
Big C
03-05-2003 15:55:51
Save yourself some money and buy something red.
Jason
03-07-2003 08:01:33
 Re: Re: super 88 in reply to Big C, 03-05-2003 15:55:51
Dont let a Red tractor scare you, just look in div 4 and 5 that will tell you how bad they are! They cant run with the BIG DOGS!!!!!
Kevin
03-05-2003 19:01:15
That is why I am going Oliver. I had red and all I did was get beat. So I am going green like I should have done in the first place!!!
Big C
03-06-2003 17:04:24
 Re: Re: Re: super 88 in reply to Kevin, 03-05-2003 19:01:15
Bet you always got beat by other RED!!!!! !!!!!
Kevin
03-06-2003 19:33:11
 Re: Re: Re: Re: super 88 in reply to Big C, 03-06-2003 17:04:24
No by Olivers!!!!!
Billy
03-06-2003 21:04:50
 Re: Re: Re: Re: Re: super 88 in reply to Kevin, 03-06-2003 19:33:11
Dont discourage the boy Kevin, there aint enough olivers for everybody and green doesnt cover over red very well!! Well, maybe with dust.
Big C
03-07-2003 17:00:05
 Re: Re: Re: Re: Re: Re: super 88 in reply to Billy, 03-06-2003 21:04:50
I got to admit the dust thing was good, but you know why they paint olivers green don't you, so you can't see them hiding in the weeds while the real tractors are playing.
Kevin
03-08-2003 16:48:06
 Re: Re: Re: Re: Re: Re: Re: super 88 in reply to Big C, 03-07-2003 17:00:05
in my club here in ohio red is last and their is only oliver green in front of the pack!!!!
Big C
03-06-2003 19:41:15
Then you where not doing it right.
